Going from 20" to 18" wheels... should I care?
~~AAJakeleg
I have these 20" wheels: https://is.gd/yu5HL7. Too much chrome.
I like these wheels: https://is.gd/QvZB06. The only problem is that these are 18", so I'd be going down from 20".
Should I care? A friend says I should stick with a 20" wheel to fill the wheel well, but I'll still be getting 285 or comparable tires. But, on the other hand, it does feel a little weird to be going from 20" to 18" which would normally be thought of as a downgrade.
What do y'all think?
Do whatever you think rides/looks best. That's a decision for you to make, not us. Lol.
You can put more meat on the 18 to fill out the well also.
I think you should buy my factory 18" midnight edition wheels with duratrac tires so that I can afford to go up to 20's [emoji6]
But really.... I think "going down" to 18's is fine. I'd even argue it's not a downgrade at all. But I'm also on the smaller diameter wheel with meaty tire side of the 18 vs 20 argument. Only reason I'm going to 20's is to be able to clear an aftermarket knuckle
There will be a difference in the two setups assuming tire outside diameter remains constant. The smaller wheels create a taller sidewall. A taller sidewall, generally, has less tread stability and steering response. It will be noticeable since its 2" in diameter. In other words, it will not handle as well.
On the other hand, it will ride smoother.
Trucks with 20's do look sharp, trucks with 17's or 18's look like they're ready to work (just my opinion). I have 18's and like the softer ride and prefer the look.
    • Hi all - my current truck is a 2022.5 1500 High Country 3.0. I bought the truck used last year. After doing some digging, I noticed that my truck's software is stuck on the original build from 2022. I have no available software updates. I talked to my dealer about this and they recommended not trying to force an update since the 36,000 mile warranty is expired. This is a big bummer since there have been many major releases since that have fixed small issues and improved speed/usability.   For reference, the current software build number is: full_gminfo37_gb-user 10 W158E-W164.4.2-QIH22B-563.3 158 release-keys Has anyone had a similar experience? Should I just forget about it and move on, or try a different dealer?
    • Sure. Buy it for me 🤣
    • Using zip ties but 2-3 they snap due to sharp edges. Just using a shoestring. Last longer. 🤣
    • I ordered the Snap On...waiting for it to come in later this week or early next week.   New front cover, new crank seal and new balancer are on. Water pump, pulley, fan, hoses, and plastics reinstalled. I can move forward knowing all my timing marks are dead on and the front engine is hopefully sealed better than it was. Take 2 with the water pump...trying high temp thread sealer on the lower bolts.   Rebuilt injector and new-new regulator is in, it looks like new. Top intake reassembled and all the bits are reconnected and snugged down.   Thinking about knock sensors again, I located both of mine and, there's your problem, Francis... The driver's side one is broke, plastic is bashed in, part of the wire is bare, and it appears to have been damaged like that for a long time. I saw the wire but didn't think anything of it. The knock sensor might not be my pulled timing issue, but it sure looks suspect. It must still be conducting, otherwise I'd expect a CEL. But perhaps with its sacred crystal inside exposed, jilted and dirty, maybe it's sending mixed signals. So I'm waiting for one of those and a new pigtail to come in. Pass side sensor looks good, except for the spark plug wire resting on it (!). The plug wires are healthy so it shouldn't be causing an issue, but I separated them and added zip ties to nearby looms to keep everything well apart.   So, I'm down to installing a knock sensor AND, oh, replacing the exhaust and cat. I actually think that's going to be fairly easy, it's all bolt-together, all new stuff from Walker is laid out on the shop floor ready to go. Hopefully have this thing on the road again for the weekend.   My luck? It will still be leaking oil, coolant, pulled timing, intermittent CEL for running rich, or it probably won't run at all -- because that's how this project has gone.   I've never worked on a vehicle so ...hurt? ...cursed? in my life. Everything has been effed with SO HARD, but I think...knock on wood...I've managed to undo all the backyard stuff and we're almost reset back to "just" an 80k mile, 30 year old Blazer.
    • Yes. You need to check out that thing, and the hub further.
