Dragweek
8secpumpgasdaddy
I finished 42nd out 135 cars in my class at dragweek last week.
I see your running twin turbos
What's your best time?
In your class who came ahead , I'm assuming all trucks?
Have run 10.89 twice. Best at dragweek was 11.12. 1995 S-10 was #1 qualifier in street machine eliminator. Cars and trucks that run 10.00 and slower. The fastest 32 run off in a bracket race. The cut off was 11.05.
    Brendan C
    Brendan C
  • Who's Online   5 Members, 0 Anonymous, 843 Guests (See full list)
