No brake fluid to both front calipers
Hi folks! I've got a 2000 gmc Sierra that I just replaced all of my brake lines on. I'm not getting brake fluid to both of my front calipers while the rear calipers get it fine . I've verified that my lines are in the correct place. If I loosen the lines at the master cylinder and pump the brakes I see fluid coming out. Also, I see that fluid is getting to the abs module because the if I loosen the lines there and pump the brakes I see fluid. There is definitely no fluid coming out of the abs module to both front calipers. Is my abs module bad? I hope not. Any help is appreciated.
Chris
Sent from my SM-G930V using Tapatalk
Just in case you don't know bleeding procedures. Close all bleeders push down pedal keep it down slowly open right back bleeder let fluid bleed out close let up brake pedal repeat till no air comes out. Work the next back the same way then go to passenger front so on making sure the fluid is kept full in the master cylinder. If you had brakes before you change the lines than you should have them after the change.
Thanks for the reply, KARNUT. That is how I bleed my brakes. But I still am not getting anything to both from calipers. After I bleed both rear calipers the pedal pressure builds up so much that the pedal can barely be moved. With both front brake lines disconnected at the tires no fluid is making it
I would loosen at the master cylinder and work from there. Could be a bad master cylinder.
I loosened at the master cylinder and got fluid coming out at both connections.
Chris
I think your question about the ABS module is where you need to start looking. Based on what you've described, there could very well be an issue there. At minimum, I'd suggest pulling it out and inspecting it.
I think I'll try that when I get home today. Any insight on what I should look for other than clogs or obstructions?
Don't you have to purge the ABS with a scan tool? Or is that just newer models?
The research I found online was mixed opinions. Some said it was necessary and others said they've done it without the tool
1. Install Combo-Valve Depressing tool J39177.
2. Bleed all four wheels (pressure- or pedal-method) in sequence (RR, LR, RF, LF).
3. Remove the Combo clip, then use a GM Tech 1 Scan Tool to run 4 functional tests while applying the brake firmly.
4. Repeat steps 1 and 2.
Hillbilly method:
Lock em up on a gravel road to cycle the ABS.
Clogs or obstructions would be the first thing. Next would be to see if there's something mechanically wrong or ???
    bellssn690
    bellssn690
  • Who's Online   0 Members, 0 Anonymous, 815 Guests (See full list)
    • This is a really late reply but I just found this thread. They won't sell the hinges. I've gone 7 rounds with them. Their solution is to buy a new cover. I'm about to buy a new cover and it won't be a Bakflip. It also won't be from realtruck.com.
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
