Jerry Nadeau
SilveradoWV
Saw an interview with Nadeau the other day and noticed his speech is a little slower. Not sure if its as big of a change as Steve Park's but it just seemed Jerry's wasnt the same. Was I imagining things or not, anyone else see that interview??
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
