GM line technician
Newbie here from N.C.
I am a G.M. line tech, I need some help. I have a 2014 6.2 Sierra, it came in with rear main seal leaking, I noticed when I got trans out and looked at the old seal that it had blew the lip of the seal that faces the fluid the opposite way, the lip was facing the flywheel thus causing it to leak. I replaced seal and 1 week later its back and seal blown the same way, this truck has aftermarket headers, exhaust, air intake pipe to throttle body and pcv hoses to valve covers. I cant figure out why there is so much pressure in the crank case to do this to the seal. My best guess is the aftermarket air pipe and pcv hoses. It also has been tuned. Anyone have any info to help? Please
Is there any sort of catch can or a check valve in line in the pcv hoses? If the check valve is installed backwards the crankcase can’t properly vent.
Sounds like warranty block and customer pay time.
The ring seal could be an issue, and no matter how well the crankcase is vented, it will still blow out the rear main.
I was thinking that too...Compression test?
Sounds like the guy has it modded and runs it hard....I'd look for a NOS nozzle on the intake....lol
A few 2014's were effected by TSB 13330 'AFM Recalibration' where the AFM controlled lifters....cylinder valves were not opening and closing at the right time which could have caused crankcase pressure problems....computer reprogram 'fixed it'. A VIN check would see if it applied to that one.
.....just thinking wildly here......A failed AFM lifter on an exhaust valve would allow a cylinder to suck in air....detonate it....no exhaust valve would open to dump it.....gets compressed until intake valve opens...sends exhaust into intake ....closed engine throttle plate keeps pressure pulse in intake....goes into pcv valve into crankcase ....creating a crankcase pressure pusle that could blow out rear main??
    Sothpaw27
    Sothpaw27
  • Who's Online   2 Members, 0 Anonymous, 410 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
