Opt7 HID kits
caskey_b
I have 2 used Opt7 Canbus HID kits for sale
complete kits including ballasts, bulbs, harnesses, and capacitors
you choose what bulb you want to go with it....
4x BRAND NEW 9006 5000k
2x LIGHTLY USED H11 5000k
2x LIGHTLY USED 9005 5000k
2x used H11 3000k
$55 shipped per kit or $90 shipped for both kits
