95 K1500 engine problem
Hello thank you for allowing me to join the group! I will set up profile and load pics when I have more time but right now I need your guyses help I've got a problem. Friend of mine has a 95 K 1500 extended cab Chevy pickup throttle body fuel injected 350, We have replaced the entire fuel system fuel pump fuel filter pressure regulator in the throttle body injectors. if we can get the pickup to start it runs good until it warms up then it will stutter and die when she comes to a stop or tries to start it again to go somewhere fuel lines are clear no rust no debris nothing in the fuel system. New distributor complete the only thing that we have not done is replace the plugs and wires and an O2 sensor we do have an O2 sensor code and we have another code and I can't remember which one it is but I can find out. Sorry this is such a long introduction but I really need to pick the brains of some guys that may have had this problem please hit me back here and I'll answer whatever questions I can with whatever knowledge I have thank you and again thank you for allowing me in
Hello BadDog500 and welcome to the site!
Make sure to post your questions to the appropriate forum and you will get a better response.
Josh
  • 3 weeks later...
Ignition coil is a possibility.  Not hard to swap, and it wouldn't hurt to replace it even if it's not the problem... about 50 bucks.  The problem sounds electrical, rather than fuel related.
New pumps have been known to fail. Did you verify fuel pressure with a gauge or are you assuming the new pump is good? O2 sensor codes can cause havoc as well. Do you have a scanner that shows live data? Fuel trims and o2 readings? Fuel system status?
wait I re-read. It's a 95. I don't know what kind of scanner live data if any you can get with a cheap code reader in a 95. Is that odb2?
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
