supreme3940 Posted October 27, 2017 Posted October 27, 2017 I HAVE A 1999 GMC YUKON 5.7 V8 WITH 179,00 MILES ON IT. THE TRUCK IS GARAGE KEPT AND RECENTLY IT BEGAN TO RUN ROUGH. I GAVE IT A FULL TUNE UP WITH THE PLUGS AND EVERYTHING BUT THE I AM GETTING LOW COMPRESSION ON THE #6 CYLINDER AND MY GAS NEEDLE BEGAN FLUCTUATING. ALSO, THE TEMP GAGE IS VERY LOW. ANY HELP WOULD BE APPRECIATED. THANKS
east3021 Posted November 1, 2017 Posted November 1, 2017 The fluctuating gas gauge is probably a cluster issue or sending unit problem. Neither would necessarily cause rough running.The temperature gauge could also just be a cluster issue or bad temp sending unit. With a scanner, see what the coolant temperature sensor is reporting. Does the upper radiator hose get hot within, say, five minutes after a cold start?What were all eight pressures on the compression test? Follow up with a wet test on the low cylinder to see what could be causing it. Sent from my iPhone using Tapatalk
