Cirlce Flies
elboberino
Circle Flies
A farmer got pulled over by a state trooper for speeding, and the
Trooper started to lecture the farmer about his speed, and in general
began to throw his weight around to try to make the farmer
uncomfortable.
Finally, the trooper got around to writing out the ticket, and as he was
doing that he kept swatting at some flies that were buzzing around his
head.
The farmer said, "Having some problems with circle flies there, are ya?"
The trooper stopped writing the ticket and said--"Well yeah, if that‚s
what they are--I never heard of circle flies."
So the farmer says, "Well, circle flies are common on farms. See,
they're called circle flies because they're almost always found circling
around the back end of a horse."
The trooper says, "Oh," and goes back to writing the ticket.
Then after a minute he stops and says, "Hey...wait a minute, are you
trying to call me a horse's a$$?"
The farmer says, "Oh no, officer. I have too much respect for law
enforcement and police officers to even think about calling you a
horse's a$$."
The trooper says, "Well, that's a good thing," and goes back to writing
the ticket.
After a long pause, the farmer says, "Hard to fool them flies, though."
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
