2016 Silverado knock
Dantree1234
Just bought 2016 Silverado 1500, has a weird knock coming from underneath the truck, I’ll be driving along and then give the truck gas and then as the RPMS drop a weird knock happens, it does it every time I do it, I’ll be driving 30mph get into the gas a little bit completely let off the gas and as the RPMS fall a knock happens out of no where, anyone have this problem?????
