B0092 Code with Air Bag Light Off and On
2005 GMC Sierra with Air Bag light on.
Use a scanner that can read SRS and a B0092 results.
Check all wiring under passenger seat and appears to be fine.
Use the erase feature to remove the B0092.
Light off and stays off for an intermittent period. In other words, sometimes the Air Bag light stays off for several
 minutes (30) driving truck and/or several start/restarts(stops).
Check with scanner again and the code B0092 has returned but the light will go off with a restart even with the code.
Do I have a problem with the SRS system or my computer?  Thanks!
The issue is with the passenger presence system. B0092 is just telling you that.
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
    • Melling I believe is/was the OEM on the lifters who explored this problem some years ago. The white paper they generated on the topic indicated two items of note when I read it. 1.) They only fail on the switch. Prevent the switch, prevent the failure. 2.) The majority fail due to deposits messing up the timing of that switch. Anyway that's what I got from it.    Mine have always been active, 195K+ now, and my oil maintenance is surgically clean.    Of course this assumes good parts. That is no heat treat issue or machining flaws. I get comfortable that these issues are in the rearview mirror by about 30K. IMHO naturally.
    • Yes, the key seems to be with the half tons that if it has the Z71, then it definitely has the two speed. What got me was that the two speed AND the lower geared towing package option could not be chosen together the last few years unless it was mated up to the 6.2. Want the 3.0 duramax and 3.73 tow gears ... nope, can't get the two speed transfer case ( neighbor son realized that after he had bought his used 3.0 half ton .. where the frick is the low range ? ! ).    I am still unsure which truck series, the half ton or the HD truck that the original poster is referring to for sure other than yes his question is in the HD section of this forum but that doesn't guarantee the question got asked in the right section.
