Dual climate control
Has anyone ever experienced an issue with the Dual climate control I realized this morning that my driver side is coming out extremely hot but the passenger side is not hot at all
Sent from my SM-G950U using Tapatalk
My guess would be a control actuator isn't working.
The actuator or flap isn't working.
:happysad:
Repair the blend door function. Often the actuator.
Where is it located do I need to drop the dash to change it ?
