Adding Tow Mirrors
Kgonzalez
Good Morning all. First time poster, long time lurker. I have spent a good part of my morning researching some confusion I have with what I'm trying to do and most of my Google searches bring me to this site. So here I am looking for help.
2015 2500HD CC Gas
VIN# 1GC1KVEG5FF539706
So truck came with the small car style power mirror/manual fold. I do not believe they have the defroster though as I do not see the logo on the glass. I would like to purchase and add some tow mirrors that have the blinker in the front and on the glass as well as the courtesy light. BUT I want it all to be functional as well. Doesn't need the power fold or power telescope though.
Found mirrors I want on Ebay and Amazon. So now I'm looking for the right harness. Chevy dealership will not provide me with the correct part number for the harness. I believe I found the correct one on ebay but the seller is now telling me in order to get all this to work properly I would then have to flash the BCM.
This confuses me as I thought I read the flash is only necessary on vehicles with memory seats/mirrors. When I asked the seller this his replay was
"Your vehicle has RPO codes "AVF" (IDENTIFICATION EFFECTIVE POINT CONTROL, 2015 1/2 M.Y.) and also "DL8" (MIRROR,OUTSIDE,RH AND LH REMOTE CONTROL,ELECTRIC,DEFOG) These harnesses are meant for vehicles with those RPO codes, and they require BCM programming"
I am very handy mechanically but horrible electrically and will not attempt hardworking etc. Also not willing to spend crazy money at the dealership either.
Can somebody please help me filter all this and see if I'm wasting time. If worse comes to worse I get the mirrors and no lights work but I would prefer they all do.
Thanks
2015 2500HD CC Gas
Thanks
I have helped over 400+ members here achieve a version of this upgrade.
Here is my thread on it. Don’t need to go through it in its entirety (a lot to consume there), just get get the entire first post.
http://www.gm-trucks.com/forums/topic/198157-2014-2017-dl8-dl3-towing-mirror-upgrade-%E2%80%93-mirrors-explained/
As for mirrors, one thing to look out for are any mirrors that have more than the factory 18-Pin connector them. Many like to have the lighting circuits on a separate connector that and assumes that you’ll hardware that.
As for harnesses, you will need to swap your harnesses out with harnesses that’ll accommodate the lighting features of the mirror.
Ok - for your 2015, since you have the AVF Code, this means you are a Mid Year 2015 and should be in better shape than if you had an early 2015.
On all 2014 and early 2015, GM didn’t include the lighting circuits at the door jamb. What this means, is that even with a door harness swap, the circuits won’t make it past the door jamb.
Here is a picture that explains that a little.
I have YouTube video links on the thread above in the first post.
Good luck, let me know if you need anything else.
Thanks!
BTW - I am on vacation, returning on 1/2. I will be monitoring threads and responses as I am able to.
Phil
Aftermarket mirrors I cant guarantee will work with the GM stuff.  So I shall give you the GM info.
The mirror kits from GM can be had black (p/n 23372182) or chrome (p/n 23372181).  They are the exact same DPN mirrors that you can order on a truck.  Power upper glass, manual lower, heated upper glass, turn signal in upper glass, backup/cargo lamp on the inside ends of the mirrors, and amber front marker lamps.
On your truck.  To make the lights work you need the following front door harnesses, 84125573 drivers side harness, and 84125560 passenger side harness.  Per the mirror install, the BCM does list a reprogram for your truck configuration.  To get the dealer to do this, you would have to buy the GM mirrors as they have an accessory authorization code to allow GM to send the reprogram info for your specifc VIN.  The dealer can then reprogram the necessary modules.
Now...could you install all of it and everything work?  Very likely.  I did my HD regular cab non AVF when I got it and I didn't have to reprogram the truck.  When I called GM with the authorization code, they told me that the truck had the right calibrations.
The GM kit are $1,100.... Can't justify that kind of money on lights
The mirrors retail for $625 black and $725 chrome.  Harnesses are about $110 each.  That doesn't add up to $1100 unless you are counting installation.  You say you are mechanically handy, grab the OE stuff from one of those online GM parts places to save some $$$.
My local dealer told me $1,100.
Regardless $700 or $800 is absurd as well. The $400 I found it all for is even killing me to spend. But I'll do it if I can get it to work
Thanks!
Phil
That thread is the main one I read. Lol Small world.
BUT I'm still confused. If I understand correctly you say LT would not need a refresh since I do not have memory anything. But then I was told elsewhere I would need a refresh.
Still confused? Do I just purchase the harnesses and it will plug and work?
In all the folks I’ve helped, none have needed the calibration/Flash/reprogram of any kind. If you are mechanically inclined, but not electrically, my DIY Kit may be your best and low cost solution. Only $50 for that and will come will the full instructions to modify your own harnesses.
And yes, in most cases, just plug it in :)
If you don't care about signal in glass or running lights, buy the "older" style.
I put "older" rounded style on my 1500. Plugged right into existing harness. Power glass and defrost worked, but signal did not. I didn't care - wanted the function of the mirror, not the LED turn signal. No power fold or anything fancy like that.
They worked great and took about 20 minutes to install (I had to drill 4th mounting hole).
Just saw with a simple search a gm parts seller with the mirror kit meaning both mirrors under one part number like was noted above for $400 something. Mine purchased thru a friend at the local dealer were $550. On my 16 the forth hole was already there. I have used aftermarket on my old truck and own on this new truck and know the own product seems to be better overall.
  • 11 months later...
Hi I have a 2015 chevy 2500hd lt with the little mirror and I have a set of tow mirrors with the marker lights and the two little lights and heated i looked at the harness at the door and noticed it was missing those 3 pins 41 11 and 9 so I have to get a hole new wiring harness to put them on
  • 7 months later...
Thanks!
Phil
How do I get a hold of the Harness Dr.  Phone number or email, walkie talkie, morris code, smoke signals?  The guys sounds like the only person who knows what the hell he is talking about.
Pm him...he'll get back to you.
Sent from my SM-N950U using Tapatalk
:). Thanks for the laugh :)
You can also email me at [email protected] if we haven’t corresponded yet.
    DaleB
    DaleB
  • Who's Online   2 Members, 0 Anonymous, 1,211 Guests (See full list)
    • My truck is a ¾ ton but my placard also says 80 for the rear tires, I think I might have the upgraded suspension to the 3500 series maybe.   I put my air down to 60 and the light was still on, and there was no way I was putting over 60 psi in the rear empty and not towing because I knew the actual number Toyo gave me and I didn't wanna ruin the center of my tires!   And you actually can change it in the settings from metric or is and it will show kph or mph then when you go into your tire settings it will be either psi or kpa, but it would be nice to just change it directly on the tire psi page
    • Common Sense Assembly   Your driveline is forgiving of the occasional mistake. It will even often forgive the random serious blunder. But it will not forgive a continuous bad habit.      What? Not everything needs to be a five thousand word essay.
    • We drove about 15 minute east today to visit a friend and saw a steep increase in price in the same county. About 50 cents a gallon steepper.
    • Sure about that? A degree wheel and a dial indicator would lower your degree of assurance in that statement. 😉    It why we have offset keys and dialable timing sprockets. Just say'n.... I've built a few and have never seen one "On the money".
    • I will admit I haven't experimented much with pressure drops beyond the numbers I put in and part of that is that the numbers I used are fairly low and then found out it would trigger regardless at that 35 psi. Having said that I had tried before had changed the placard pressures and being that I have a 1 ton set to 80 on the placard for the rear I believe it triggered close to 60, the front I don't recall now for sure but thought maybe it could get close to 45 from that factory 60 placard pressure. So I never did figure out if it was a number of psi from placard pressure to the alarm or a percentage of the total placard number as some figured it was like a 25% drop from placard pressure would trigger it. So as to try and answer your question, I believe I set the placard pressure on the front to 47 or so and while I run the front tires at 40, they have dipped below that some if its colder and I haven't put "winter air" in yet and never once have had the front alarm go off. I would say that the answer your looking for is no, that if you set your placard pressure to 45, you have a certain amount of room to drop below that pressure before the alarm will go off.    The pressures you decide to run in your truck, that ends up being what makes sense to you based on what your carrying in your truck or if towing, then have to bump them back up to something that will carry the load in the rear and the fronts typically left at the same pressure. It all comes down to that chart I put the link to and using an accurate roadside scale to be your guide, both unloaded and then loaded to know your minimum safe pressures.    I just wish GM would allow a person to change the readings for the tire pressures to the English system of pounds as I have to look at that goofy metric reading that will never ever jive in my head and will go over and change it just to figure out what they are if need be and then change it back.
