  • 3 weeks later...
21 hours ago, cossack said:
Also remember that in during warmer month transmission thermostat stays open almost always.
I think it stays open during winter months too. I mean there seems to be little change in trans temps depending on ambient temps, just like our coolant temps.
On 1/5/2018 at 2:41 PM, Eddie 70 said:
I got to thinking about the trans temperature and this remote filter. My drive is 40 miles one way. When I get about 2 miles from work, my trans temp is just getting to 170 degrees. If I understand correctly the flow through the remote filter would not happen until this point. I like this idea but think it is a lot of work for two miles of filtering. Am I missing something here?
Thanks guys.
I’m about 90% sure it doesnt open until 190-195 degrees.
The thing is the filter doesn’t need to be constantly filtering. It just needs to do it once in awhile.
picture having a loop of water running through a brita filter. It’s not going to make much difference if it runs through continously or just does it once a week. The filter should remove most of the contaminants on one pass.
If you’re only reaching 170 on your way to work, I suggest having a little fun on your way to work once in awhile.
You are correct it does open during winter month too, it just takes substantially longer then during summer. At least it does in my truck. How ever during summer time transmission reaches operating temperature quickly.
I went ahead and did an oil change on the truck but decided to leave transmission filter in till the next time. It hardly had any miles on it sense the install, figured it would be pointless to change out.
I'll try and update this  thread once I have filter changed out.
  • 4 weeks later...
I was following this thread a while back. Just sending a reminder that we'd love to see that trans filter opened up when you feel the time is right.
You got it. But it will probably be closer to summer time when I change it out for the simple fact of very few miles on it. Also might do a pan drop to see how it looks on the inside, if there are any shavings. Stay tuned.
  • 1 month later...
Awesome Job! Your lines look super professional! Im considering doing this but with rubber trans hoses, only one question. Is there any down side to this? Would this restrict the flow of fluid at all? Might sound like a dumb question, but I just didnt know.
Thanks!
  • Thanks 1
Thanks!
Thank you!
You can definitely use rubber trans hoses. I think those radiators have 3/8 NPT threads. Just make sure clean out old sealant and use good quality thread sealer, I would recommend against the tape kind and go with the liquid type.
The extra plumbing and the filter itself probably add a few PSI resistance, but I doubt its anything significant. The pump is a positive displacement type and flows same amount of oil no matter the PSI. Either way I don't have a good solid answer for you man. I would have to measure pressure difference between Point #2 (filter out) and point #13 (filter in) on parts diagram. Also would need to know the pressure relief setting on the pump before I could answer your question with 100% accuracy. But again I doubt that this setup changed the amount of oil that flows through the coolers.
Hope my nonaswer helps you make a decision.
and bump for the updated first post. Got pictures of the filter put up.
Edited by cossack
Just read the updated post with filter pics. The exact reason I wanted to install a remote filter in the first place. I'm still pulling a gallon of fluid from the dipstick tube every 15k miles until then.
6 hours ago, cossack said:
Thank you!
I went ahead and installed a set up similar to yours using rubber trans hose and Hayden 397 adaptors for the cooler and radiator. Same filter head but a wix 51515xp filter because it was black. Also brass fittings off the filter head painted black.
Install looks great, how many miles you got on it now?
Only about 700 miles. Next month I plan to do a pan drop, change the fluid and both filters. It only has 17k miles on it but I am interested to see what everything looks like.
    Sothpaw27
    Sothpaw27
  • Who's Online   1 Member, 0 Anonymous, 414 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
