Tire Pressure
Tobes
I finally got around to seeing if the tires needed more air.  I look at the door and it says 35psi all around for the 265/75 16s on the Z71s.  The pressure in the tires was 40psi.  When I deflated the tires down to 35, they looked like they do not have enough air in them.  What pressure do you all keep in the tires.  As far as I know, it looks like the dealer put 40 in them (but I have seen them not inflate tires to the proper pressure way too many times).  Thanks for the help
I've used 35psi all around since new and they have a lot of life left. They have only been rotated once (bad me). 36k on them now and that is about the best I've ever gone with OEM 4x4 tires. 50k looks quite possible at this rate. The front tires do look a little plump at the bottom at 35psi but it works.
The stock Firestone Wilderness tires are only a "P" rated tire (passanger car).  They don't have the strength to withstand higher pressures.  GM puts these soft tires on your truck, so that it rides like a car...  (doesn't help if you want to haul much of a load though! )  I'd stick wwith the recommended psi on the door jamb.  If you want to put some "LT" rated truck tires on you can run higher pressures.  I think the stock wheels are rated up to 60 psi.  (Help me out here Mountaineer Tom 'cause I know you know...)
Now that I think of it, I picked the truck up a couple of months ago when outside temps were near freezing and it has been up near 70 today when I looked at them so there might have only been 35psi in them when they delivered it.  I just wanted to make sure there wasn't a reason for the extra 5psi that i needed to know about.  With the reputation of Firestones on a "different" company's light trucks, I did not want to overinflate them for no reason  ;)
What year truck do you have? my 99 has 245 75 16 Goodyear Wranglers but it is not a Z71. The tire says 'standard load' max press. 44psi. I didn't know that any og our trucks got Firestones.
It's a 2002 Z71.  I bought the truck before I saw it or I would have said something to the dealer.  Since the dealer is a little over an hour away and they wanted the sale, they offered to drive it down to where I live.  I did not mind since I was not looking forward to spending a half-day pick it up.  I would have thought Goodyear or Michelin, but hey, this way I get to pick the new tires I get.  Maybe later, maybe sooner.....who knows
I'm not sure on the rating on the wheels themselves.  Actually, I don't recall seeing/hearing any info on the psi rating on the wheels.  ???
I try to keep my stock Firestone tires around 34 psi most of the time and I feel like I've gotten good wear out of them.
=  Actually, I don't recall seeing/hearing any info on the psi rating on the wheels.  <!--emo&???
I thought you had a stock rim off you truck and looked at the  forged rating of the rim once...  sorry Tom...  This crap happens when you are an old fart!!!   LOL   (15 months from 40!!! )
Sorry guys!!!
i ran my fstones at 35 until the day i dumped them
I run 50 rear and 52 fronts on my BFG's now
Thanks for all the input guys.  I guess they look fine at 35.  We'll see how long I can stand keeping the 'stones' on the rims.  I just hate to throw away a tire that still has tread left on it.  I wish dealers put better tires on our trucks.      :D
I went to the Firestone dealer with my '00 Silverado and he gave me credit on the stock tires towards the purchase of Bridgestone Dualer LT's.  I replaced all 5 tires for about $130 mounted and balanced.  The stock tires had about 1000 miles on them, and I used the 100% satisfaction guarantee as my leverage.  I told them I wasn't happy having a "p" rated tire on my truck and I didn't think it was heavy enough to do what I wanted.  They honored my request, but only for Bridgestone tires (which I thought the Dualer was a darn nice tire).
    btm
    btm
  • Who's Online   5 Members, 0 Anonymous, 1,432 Guests (See full list)
    • Here's the second UOA on my 22 Wrangler with the Ecodiesel. This has 5k miles on AMSOIL Signature Series DEO 5w-40. The first one was dealer installed oil, no clue what it was, the second is what AMSOIL recommended, European FS 5w-40, Most of the Ecodiesel world is showing great results using the European MS 5w-40, I figured I would see how the DEO works. This is using an Ecoguard oil filter. It's my understanding this engine likes to shed aluminum.  We will see. So far I don't think this is too bad.
    • I'm surprised nobody seems to offer a solution like the start/stop device I put in my new truck. Remembers my setting when shutdown. And while it still starts up in start/stop, it stores/evaluates what mode it was in when shut down and will change it whithin a second or 2 of startup. It'd be nice to have something like that for the DRLs.
    • 2015 Sierra 1500 here. Leaks from the sunroof to front driver side and soaks carpet. How do I fix this? Thanks!
    • I will be doing that for sure, but I need to solve who has/ where I can find a bidirectional scan tool that will support OBD 1.5. I'm kicking myself because I ebay'ed a Snap On MT2500 that I didn't think I'd ever need anymore. D'oh!! I'd rather not buy another, so I'll contact a few local shops to see if they have one and how much they'd want to do the procedure. I'd rather have the ability to do it myself... I wish there was a modern tool that could do it all, but I'd have no idea what to buy.   The theory with the pulled timing is that it mimics a rich condition. The delayed spark causes incomplete burn and the O2 sensor picks up low oxygen levels. That's interpreted as a rich condition so the PCM pulls fuel and that shows up in the deeply negative fuel trims.
    • An ultra wealthy man had the most beautiful daughter. But, there was a problem. Everything she touched would melt in her hands. No matter what, Metal, Wood, Stone. Anything she touched would melt. She could not feed herself. Because of this, men were afraid of her. Nobody would dare marry her. Her father was despaired. What could he do to help his daughter? He consulted doctors, scientists and anybody who could solve this problem. Finally one of them said, "If your daughter touches one thing that does not melt in her hands, she will be cured." He was overjoyed and came up with a plan. The next day, he held a competition. Any man who could bring his daughter an object that would not melt in her hands would be given billions of dollars to marry her. Three extremely intelligent and handsome young men took up the challenge. The first brought a very heavy steel rod, But alas, when the she touched it, it completely melted in a matter of seconds. He sadly went away. The second brought a beautiful diamond, knowing diamonds were one of the hardest substance in the world and would not melt. But alas, once she held it in her hand, it melted. He too was sent away disappointed. So now, there was one left He was very nervous & sweating. He approached the daughter & said, “put your hand in my pants pocket and feel what is in there." She did exactly what he asked. She felt something very hard. She held it in her hand, squeezing it as hard as she could. It did not melt & remained extremely hard. Her father was overjoyed. Everybody was overjoyed. She was finally cured. Nothing never, ever melted in her hand again. They married and they both lived happily ever after, raising a wonderful family. Question: What was in the the groom’s pants pocket??? Answer below ↓ M&Ms of course! They melt in your mouth, not in your hand. What on earth were you thinking?
