HOW TO: Replace your 2014+ Door Lock Actuator
The driver's side door in my 2014 Sierra decided that it no longer wanted to be friendly. When I hit the remote, it just wouldn't respond. You either had to use the key (in the hold. from the outside), or push the pin/pull the door handle from the inside to get the lock to work. I ended up buying the door lock actuator from GMPartsDirect. Part number 13597536.
Tools:     Door Panel Tool
                10mm socket + ratchet
                Torx T25 nut driver or bit/universal screwdriver
                Torx T30 nut driver or bit/universal screwdriver
1)    Remove door panel and pull off the vapor barrier (Link to video. You can ignore everything after the 3 minute mark)
2)    Disconnect the door lock actuator. Remove 3 Torx by the door latch. Loosen the 10mm bolt by the wire harness. Disconnect the wire harness. Remove the vertical door lock pushrod.
3)    Remove the window guide. Reach inside the door, it runs along the back of door. Black rubber piece that the glass slides into. There are 2 10mm bolts accessed from the outside of the door skin.
4)    Remove window actuator harness grommet and 2 wire guides – get that stuff out of the way. You’ll need all the space you can get.
5)    My truck had a black plastic foam thing, maybe 8”x4” that was fastened/double sided taped to the inside of the door skin. If you have this, you need to remove it. (I wouldn’t use any metal pry tools for this, you don’t want to dent your door from the inside)
6)    Remove lower bolt from rear window support. Loosen (but don’t remove) the top bolt for the rear window support. Don’t worry, your glass won’t fall.
7)    Remove the door handle. (Link to video), then loosen the T25 bolt underneath the front part of the handle.
8)    Back inside the door, reach up and slide the door handle mechanism forward to release it, then pull it down into the open cavity to give yourself room to work on it. Disconnect the linkages that connect the door handle mechanism and the door lock actuator. I took the cables out of the wire cable guides to create more slack for myself.
9)    Now for the fun part. At this point, you should have a door lock actuator just sitting inside the door frame, with a vertical window support and a horizontal door skin brace keeping you from removing the actuator. Grab the lower part of the window support and push it (hard) as far into the door as you can (away from you). With your other hand, grab the window actuator and try to twist it through that opening. Think about it like you’re trying to get a couch through a small doorway. It is a very tight fit, and your knuckles are surely gonna get knicked, but with the right combination of pushing (the window support), pulling (the door lock actuator), and cursing – it will come out.
10)    Once you have the old actuator out of the door, pop the access covers to swap the cable assemblies over to your new door lock actuator. Or I hear you can rebuild the old one, but that wasn’t the route I took.
11)    Rinse and repeat. No real magic to putting everything back in. (do remove the weather stripping and weather stripping clips from the door panel, though. Install them back on the door before you put the door panel back together)
Thanks to Waterfowler41 for his guidance! I'm happy to help if anybody else is looking at this job.
All in, it's about a 2 hour adventure. Parts are in the $50ish range.
  • 9 months later...
I have 2015 z71 Silverado 1500 crew cab. I tore my driver side rear door apart because I had this same issue. Before I did all of that I ordered what I thought was an actuator. It turns out it may be the actuator motor. Should I replace that or the entire actuator?
Ps: is the picture above the actuator? Below is a picture of what I was sent
I ordered the complete actuator and picking it up today, but I saw some videos for replacing the motor and it looks doable. I wish someone would have made a video of the 20115 actuator replacement. Plenty of the 2007 to 2014 but I couldn't find any for the 2015 Silverado / Sierra model. Anyone know of one please post the link. Like to think I'm pretty savy about searching for stuff but I have come up with bupkis.
  • 1 year later...
I'm not a member, but will be soon.   I have 2015 Silverado and the passenger door lock is having problems opening.  It works from the drivers door, but not the remote.  I was almost going to order a new lock when I noticed the GM part description "Extended range keyless remote door lock". What caught me was "Extended Range Keyless".  With that description, the lock is getting a command from the FOB.   I changed the FOB battery works perfect been testing all day.    FYI.  Steve
    • I have a 2024 Chevy Silverado 2500 with the 6.2 liter engine, Vin: 2GC4YME79R1273849, with 27,437 miles. Recently we took a trip from Candor, NY to Townsend, TN pulling our fifth wheel, when I got close to the Townsend, TN area The truck gave me a message of low oil. I checked the dip stick and found it was 2 quarts low. Today, August 27, 2026, I had the oil changed and the technician Found the truck was very low on oil.  Is there a Recall for this? What is my recourse for this issue? Do I call the dealer where I bought it or any chevy dealer?   Robert Strickland 292 Owego Road Candor, NY 13743 352-502-6588 [email protected]
    • We understand the importance of understanding how your Sierra performs, @SoCal Angler. Our team would like to gather the proper details to assist you with your inquiry about your truck's automatic braking. When you have a moment, please visit: https://s.chevy.com/support-request and fill out the request form with pertinent details. This will ensure your request is routed correctly so we may take a further look. We will keep an eye out for your outreach.
    • That is the funnel kit I bought and for being here in Canada I did get a better deal than what other sources were charging through a certain supplier in town that sources more directly and they ordered it for me. There are other items now on the market which would be perfect as well but this has worked well which was the hope when I bought it. I mentioned the Amsoil quart bottles as they have that squarish shape up top and it props nicely on the rim of the opening without falling into the funnel so I can leave them sit and drip a bit. You may have already figured out that to get the cap off the valve cover unless one is 7 + feet tall its not going to be reached without standing on a step of some sort and so when I do that I put the right adapter in and just leave the elbow on the funnel all the time anyway and open the lid and then if using quart containers for sure I can stand beside the truck and leisurely add the oil, and I can leave that funnel on when starting the engine to let it idle to fill the filter and then add the rest of the oil to top it up before removing the funnel and putting the factory cap back on. I put the cap back on the top and slide the bottom cap on as it fits onto the elbow adapter also and then store the funnel in a clean household plastic garbage bag along with the adapter so I have no reason to be washing out the inside of the funnel as I keep it completely clean between uses.    Draining the oil as per the under the truck portion, yes indeed that is slick as someone was thinking on GM's part there and admittedly I don't drop the oil screaming hot in this truck due to the exhaust being there and makes it safer as far as the oil temp if its just warmed up some instead as I don't have the truck on any ramps etc as I do it as the tires sit on the garage floor. The filter is not boiling hot then either and can drop it off into another pail after pulling the drain plug and just leave it drip out. Go back under a few hours later with new filter in hand and clean off the filter base and put the new filter on and install the drain plug. The filter is a little cramped in there as per wrapping ones hand around the filter and I am so used to using the band style filter removal tool that its no big deal and same for snugging it up. My filter wrench is many years old now but I think this is the current version and sounds like the right size, just in case my explanation was not great ( those nylon strap wrenches that one tool fits all filters are not my favorite tool to use, I much prefer this style personally )     57020 Swivel Gripper - No Slip Filter Wrench - Small | Lisle Corporation   And again about the oil draining and filter setup under these GM trucks, I've watched Ford videos of them struggling with oil flying sideways out of the oil pan on the gas 7.3 due to the sideways drain plug onto other components or cross members and guys trying to make shields out of carboard etc and other Ford pickups that Ford insisted they have sideways drain plugs. One win for GM there anyway with this engine.
    • Kind of off topic, wife drives a 2023 Yukon Denali with the 3.0, been a great rig so far, incredible fuel economy for a truck that big and heavy. Coming up on 50000 trouble free miles.
    • I`m gonna try some of this in my 2000 LM7 that has had the famous piston slap since 17,000 miles or so. I have used Mopar combustion chamber cleaner down the spark plug holes a few times in the past. Corrects the problem for a few months or so. Then returns. GM top engine cleaner has been used also. No good results from this.   This LM7 never used oil. Even running the piss out of it.   Course, I`m gonna use this in my 2025 L84 while it`s still clean. It`s got 13,000 miles. Used Chevron fuel system cleaner [2 bottles in tank] a tank or 2 ago.
