autodim outside mirrors
i have a 2014 gmc sierra 1500 slt with the drivers side auto dim outside mirror (also power folding, turn signal, with the puddle lamp)
i know i can buy the auto dim glass for the passenger side #22919749, does anybody know if the truck is wired for this?
how difficult is it to remove and replace the glass?
Phil Gamboa, makes a plug and play harness for this. I believe is missing some wires but in his harness he adds the wires you need., my didn’t come with it and after he installed it works like charm.
My bad, I thought you were referring to the inside rear view mirror., but I’m actually interested on this. Phil Gamboa be your guy to go to as far wiring and connections.
Check your door jamb and see if you have pins #5 and #6 present on the cabin side.
Here is my thread on how to wire it. Auto Dim is dependent on several factors. It gets its signal to dim from the rear view mirror, so you’ll have to swap that too.
http://www.gm-trucks.com/forums/topic/192050-how-to-a10-inside-rearview-auto-dimming-mirror-conversion-dd8/
thank you I will check that connector.
i already have the inside auto dim mirror and the drivers side auto dim outside mirror.
There will also be additional circuits from the driver side mirror harness that’ll need to mate up with the door jamb connector as well.
Good luck!
There is no such thing as a pass side dimming glass. I bet the options ask w/dimming to verify its a DL3 so it has the turn signal. You can see pics of the glass with that part number and it’s not dimming.
If you look closely on the face of the glass on the drivers side, you can see the outline where the dimming happens. No such luck on the pass side. It’s been that way since ‘03 on the silverados.
    CaptainDad
    CaptainDad
  • Who's Online   4 Members, 0 Anonymous, 394 Guests (See full list)
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
