Another new guy from TX
UNTsilverado50
Hey guys, long time lurker and member of other GM forums. Been finding that this site is one the best and most active, lots of great information. I'm a long time Silverado owner - I've had a '92, '96 and currently an '06. Been truck shopping lately so I'll be adding another soon.
Here's my current ride - 2006 Silverado LT 5.3L, 2wd, 151k miles with a torsion crank, Fuel Octanes and 285/70r17 Cooper Discoverer ATP.
Nice truck!  I visit your area quite often and would love to take my truck on your terrific highways.  Unfortunately,  I find myself cruising them in a rental sedan!
5 minutes ago, UNTsilverado50 said:
Thanks! I'm up in the Cypress/Tomball area
Cool. I'm in Pasadena. So basically like the other side of the city. Ha.
    Fishboat
    Fishboat
  • Who's Online   1 Member, 0 Anonymous, 511 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
