Radiator swap
In the process of tracking down an overheating  Issue I purchased a new radiator. Purchase the 34" instead of the 28.  It didnt occur to me that the fan shroud wouldnt fit.  What are my options.  Dont think i want to invest in an electric fan swap.   Did they have mechanical fan shrouds with the 34" radiator?
What's the year make and model of your vehicle and I will see if I can help you further. A electric fan would cost less than $100 though...
2000 silverado 1500 with 5.3.  Mine has mechanical fan.  If i swapped an electric fan setup in i would want it to function like factory.  No switches.  Adjusts speeds per temp. Adjusts with AC.  ETC.
