Best Place to Purchase Cognito UCA's?
I searched and didn't really come up with anything other than EBAY dealers or straight from Cognito. Where have you all been purchasing them from, and have any of you found a decent deal? Getting my parts list put together to do these when I change the front struts over to Bilsteins. Have a 2.5" level with stock struts now, will be running the 5100's at max with possibly a 1/4" top spacer.
Also, those of you with aluminum upper and lowers, any issues switching over to the Cognito uppers, and did any of you press in new lower ball joints to the aluminum arms with success?
Thanks
Thanks
Mrt motorsports. I also had my lower ball joints replaced with new units made by moog.
I appreciate the response. Moog is what I was planning on using, I'll check out MRT's site as well. Did any of you replace the bolts and nuts where the LCA mounts to the frame? I read these were a one time torque thread or nut, is this true?
I didn’t replace the lca, just the lower balljoint.
Did you cut off the drop stoops when you installed the UCA's? I noticed in the installation notes Cognito mentions this. Upon researching I have seen some do, some don't.
Installer cut mine off.
I searched around and all the venders seemed to be within $10 - $20 of each other.
I finally found the ones I was looking for on Amazon, and if you have an Amazon credit card you get 5% back on all Amazon purchases. Paid $490 with free shipping, and got 5% back on my credit card. Not bad if you ask me.
  • 1 month later...
    LonghornMM
    LonghornMM
  • Who's Online   5 Members, 0 Anonymous, 542 Guests (See full list)
    • Because single shot injectors are ancient and multi hole injectors provide smoother running engines and sharper throttle response due to the fuel being atomized better..the best lead I have is a 24lb blue top injector almost everything matches up but the injector will put out about 26lb/hr which is just outside the gm threshold.figured id ask here to see if there was an absolute answer
    • Why is my question?   Any change in injectors requires a tune. Unless you are going back with the OEM part number or a newer part number of that same injector.   Any size difference or type difference like the EV6 style injectors all have different injector data for them. And there is no EV6 injector that matches the factory 25 lb/hr size that your truck comes with. I've been messing with these trucks and tuning them for a long time and what you trying to do doesn't exactly make sense to me.
    • My 6.6 gas lt8 had lifter noise with 28000 miles bought new 2026 and while driven to dealer it threw #1 rod bearing “HD my ass” good luck with yours i hope it don’t turn a rod bearing!
    • When a condition becomes a business model.    https://www.gm-trucks.com/gm-truck-suv-incentives-pricing-2026/   Zane posted this in "Latest Articles".    The honest bottom line   Truck buyers have spent three years assuming this is a temporary condition that will break once inventories normalize. GM just presented it to investors as a durable strategy, on a chart, as evidence of good management.   Inventory did normalize. GM is at 511,000 units and squarely inside its own 50 to 60 day target. The discounts still did not come back, because the low incentive number is the goal rather than a symptom of shortage.   Plan your purchase around that reality instead of waiting for it to change. Follow our ongoing GM News coverage for pricing and incentive changes as the next-generation trucks land.
    • Thought it was raining this morning when we woke. Nope. Dew point was over 80 F and humidity 98%. Zero visibility distance. Everything was 'sweating'. I've seen rain come out of clouds but never out of Pepper or the tree trunks.    Wicked storms just missed us sliding off to the east but by blocks. Heat index about 110 F with air temp in the 90's.    This is  our third wave this month of multiple days of this type of weather. And yet the grass is going dormant and the ground is cracking this side of the street and water up the the hood opposite. Just weird stuff going on.
