Largest Nitto Ridge Grappler
Hi there. New to forum, thanks for the help/advise.
Have a 2018 GMC Sierra Crew Cab with stock 20 inch wheels and have a 2'' level kit. Really like the Nitto Ridge Grapplers and was hoping for some advise on the largest size that will fit with my stock rims . Looking at the 285/60/20. trying to get the tallest and widest tire
I have 285 50r22 (33.26) terra grappler g2 on mine with no rubbing at all when I had just a 2" level.  The tires you are trying to run are about a 1/2 in taller and not quite as wide, I think youd be ok.  I put 2" spacers on and the rubbing was undriveable though, good bit of cutting wouldve been necessary.
Edit: The offset is going to come into play.  Maybe trying finding some similar set up on the custom offsets website.  You can narrow it down a bunch of different ways to get something similar.
im running 295/55 toyo's on my truck. I have a 2" level and they rub the UCA at full lock. Take a look at the Toyo Open Country RT. they are cheaper then the Ridge Grappler. I ended up getting all 4 for $1250 installed
    appletrav
    appletrav
  • Who's Online   4 Members, 0 Anonymous, 430 Guests (See full list)
