LED bed light not working
So, we finished moving (into storage...) and during that process I realized that one of my LED bed lights that the truck came with doesn't work.
I've considered taking it to the dealer, but they're not very bright, I'm wondering if this is a common issue, and if it is, would you recommend getting some cheap LED fog lights? (can that even work?) or just go back to the dealer to fix it?
I don't use my bed often, but it has a soft roll up cover I got from Amazon, so its dark in there all the time.
I'm wondering if maybe theres 2 fuses or something? My dad tried hitting it (with his hand.. not a hammer!) and it didn't even flash. I don't know if its ever worked.
More than likely just a bad light, but the easiest way to verify would be to unplug the good one and swap it to the other side.  If the good one works, that tells me the other one is bad.
They are just screwed on. They tie into your cargo lamps, so it’s just one fuse. Maybe loose connection or bad led.
Just get some replacement light pods or better yet strips off Amazon.  You can cut the wires of your existing lights back near the rear of the bed and splice the aftermarket ones in.  They will work fine (and if you get the strips they'll probably through off a more "even" light).
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 910 Guests (See full list)
