Hello there. I hope that someone can answer this one.
I see there have been some postings about heating and AC problems. I have a 2006 GMC 2500HD with Duramax. It only has 138000 KM on it so far.
In the winter, the heater will start blowing ice cold air from both sides. I do the recalibrate sequence and it behaves for a while. I have driven many miles in -30 deg C weather with no heat.
In the summer, the driver's side will pump out the heat. The pass side is cold. The recalibrate only solves the problem for one restart. This heat issue has been around a lot longer than the cold issue.
Are these two problems related? What do I need to replace to fix this?
Thanks for your help!
Laurence
 This truck needs a new blend motor assembly ( tiny gearbox and motor) .
Hello again. I replaced the blend actuator and I reset the system (recalibrate). It was wonderful to have AC again! But; the the same problem started again. Full heat from the driver's side. The pass side is cool.
The actuator I replaced is mounted under the duct work; accessible from underneath the dash.
Any opinions on what this could be?
Help!
Edited by Laurence
Oh; there are two? I did not know that. Anyways, I replaced the one that is reached from the passenger side. Where is the other one? The motor I removed did not seem to have any defects.
Laurence
It's near the dash brace going to the transmission hump on the drivers side.  You need to remove the cover/shield running along the middle of the dash (along the underside of the dash).  It's fun, several blind bolts that you need sockets just the right length to do them...
There needs to be two, so the two side can have different temperatures.
Driver's side actuator is on the bottom of the HVAC assembly, above the transmission hump accessible from under the dash.  The passenger side actuator is on top of the HVAC assembly.  It is accessible by removing the radio.  Not too tough, you will see it in there a little to the right.
  • 5 years later...
Well guess what? This problem is still not solved! I replaced the drivers side temp blend door actuator (underneath on the pass side) a couple of times but no change. I had it diagnosed at the GM dealer and they said the pass side actuator needed to be replaced (?). So I did thinking perhaps the controller was getting confused. I thought it was OK after but eventually the problem came back.
The actuator motors I used were not Delco but Dorman. When I reset the system all works good for a while but then the driver's side blows hot in the summer and cold in the winter. The blend door moves freely.
So the only things I have changed are the blend door actuators. Nothing else. I have moved the actuators around but it is always the driver side that is bad.
Do you think replacing either the cabin or duct temperature sensors could help?
I don't use the truck much and that is why this issue is dragging on so long.
    • If we actually used any significant amount of that source in the USA then I'd agree but we don't. We've had that discussion before. We drill and pump more than we use. Thing is, we sell. We export. Gas and Crude. It's more profitable so any shortage here is self inflicted and LEGAL.    I worked a gas plant that has multiple fuel sources available and I worked in the furnace and boiler plant in that facility. I'd had days we swapped fuel types four times in a twelve hour shift which isn't done on supply but on margin. Two of the fuel sources are internally generated. Tail gas and DAK, both of which are sold as well a consumed. We always had more than we needed to run the process but we chose the fuel that produced the best margin not bought at the cheapest price always. A good bit of math to that and back in the time that was done on a slide rule.     I worked the Shale Oil Semiworks of Chevron Research and CONOCO Research in Salt Lake City. That process never went into production although it was very successful. Why? Did we lack oil bearing shale? Nope. Price of crude never made the margins work. That was in the late 70's early 80's. Remember history? What was happening then was a reaction to that situation. It didn't drive it. If so then it's easy. This isn't a supply and demand thing. This is a profit and margin thing and AI rules that now.    In no refining situation that I was ever in would a bomb hitting a well anywhere in the world 'instantly' interrupt or even distress the supply. Most plants have more than a months worth of crude in the tank field and more in pumping stations. That yo-yo could play out over days, weeks and maybe months and have zero impact on plant operations. How many times has this been off and on in the last few months? These people and not stupid. These plants measure down time in hundreds of thousands of dollars per day. They are not sucking fumes or waiting on the next truckload with baited breath. Besides, as I noted, they are for the most part 'vertically integrated'. They own it from the dirt is sits in to the delivery rack and sometimes to the pump. It has a HUGE shock absorber built in. When production suffers, refining wins and when refining is winning exploration is killing. The rest of that crap in the news is a 'news cycle'. Government dipping in to reserves? Oil is stealing their milk money. There's a reason Chevron abandon Venezuela infrastructure and it had nothing to do with security of US citizens. Nationals run those plants. it has to do with MARGINS disappearing to corruption. They are in no hurry to return. Is there supply there? Oh yea. More than enough to offset what is bought in the middle east. Just isn't ???? Profitable.    We have supply. There are places in Illinois you can drive a pipe into the ground and run your homes natural gas furnace on it.    A refinery fire will gum up the supply works but not a localized war where the market is using a limited supply from. Now Europe, that's something other....
    • $4.00 a gallon here now.   Diesel nearly $5.00 again.
    • If we're talking futures, yes, it's speculation.   The spot price of a delivered barrel is elevated now compared to before the conflict. And that is related more to current supply/demand.
    • SPECULATION on the wars effect raised prices. AI is maximizing the profit. Refining is vertically integrated.
    • It's the Middle East conflict that raised prices, not AI. But nice distraction.
