Park Assist Technical Question - 2008 GMC Sierra
I have a 2008 GMC 2500HD Duramax. When i start the truck, it says park assist off even though i did not turn it off. The park assist disable button is also always lit up, and will not let me turn it back on. I have put it in reverse and the sensors do not buzz. I also connected a TECH 2 and i cannot even communicate with the park assist module. The LED on the rear pillar are not lighting up either when trying to test with the scan tool , also due to not being able to communicate with the module.
Have any opinions on what to try next?
35 minutes ago, starman8tdc said:
I would check your wiring diagrams. Any related fuses? Is the module getting power? Is the module ground good? Are there any signal "on" wires to the module, like what an amp has?
i have checked the related fuses. I will have to find pinouts for the module to see if it is getting power, and check the ground as well. thanks for the reply
    appletrav
    appletrav
  • Who's Online   1 Member, 0 Anonymous, 216 Guests (See full list)
