2016-2017 Glove box USB part #
Does anybody with a 2016-2017 have their glove box taken a part, that can give me the number of the USB port?   I've replaced the HMI and Radio in my 2015 with a 2017 model to get Car Play, and I need the later model USB port to make it work.  It's the single white port.   Thanks, Don
I realize it's the cable coming from the HMI that needs to be replaced as what is in the glove box is just a holder for the cable.  If anybody has any info I would appreciate it.
