99-00 Escalade/Denali cluster
I would like to replace my gauge cluster with a 99-00 Escalade or Denali cluster with the 120 moh speedo. But I was wondering if the speedo will work correctly in my Tahoe. I know I will have to have the odometer transferred, but will it work besides that. They have the same engine and mine is an Auto-trac 4x4 too.
Thanks
Yes, it will work. It's a bolt in deal. If you are good at working in little things, you can transfer the odometer yourself. You just have to carefully pry the faceplate off the cluster to gain access to the inside, then remove 4 screws and the odometer, and switch them out. Not hard at all, I did it in about 10 minutes when I got my escalade cluster. Good luck getting the cluster itself, though. They are no longer manufacuctured by GM and are scarce!
They are available-check this url:http://gmpartsdirect.com/results.cfm?singlepart=1&partnumber=15073350
Just save your old unit in case any warranty work arises.
Have a great one!
Nope that is the 2001-2002 style, that only fits NBS. I need one from a 99-00 to fit a 96-99 Tahoe
    250.3k
    Old Bay
    Old Bay
  • Who's Online   4 Members, 0 Anonymous, 647 Guests (See full list)
