2017 Denali grill options
Hit a turkey early this morning. Only grill damage. Looking at this as an upgrade opportunity. Any ideas other than billet grill? Thinking about going with the 2015-2017 grill.
I bought a 2018 and instantly changed to the 2017 grill. Truck looks soo much better. The new grills are not an improvement.
  • 2 months later...
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
