2018 GMC 3500 HD Duramax
I just purchased a 2018 GMC 3500HD with the Duramax Diesel for the motor.  I like everything about this truck except where the DEF (diesel emission fluid) box is located on the passenger side.  I don't think anyone at GM really thought this through.  Currently i don't have any running boards on it, so i sticks out like a sore thumb.  I was  wondering if anyone has moved the def box to a different location?  I would love to move it before it gets ripped off or crushed.
Go to the duramax forum, I think there is a thread on there about this. There was even a company that makes a kit to move it into the bed. Unless you're logging or jumping rocks I doubt you'll hurt it. Haven't heard of anyone yet that's tore one off.
I do agree it's kinda ugly.
This and the wide diameter tailpipe add to the charm and macho appeal of a diesel, imo.  It's all part of the support network that makes your truck the toughest and strongest in the lineup.  Don't hide it, flaunt it!
Cheaper option might be a aftermarket skid plate there are several different companies that make them for the dirty D. 1/4” steel plate only way your piercing that is with a bullet or crushing it...
While your here does GM still make you open the hood to fill the DEF? I always thought that was beyond dumb. I’ve seen on the Colorado the filler is in the right spot, and I’m assuming it will be with the 019 1/2 ton Silverados as well?
I'm it I'm the one in a million!!!!  I did knock a hole in my DEF tank, how I did it I have no idea!!!!  I installed an Or-fab DEF tank skid plate and have not worried about it since then.  I don't thin they are still building them but you could check.  Also I think that the later models it already has a steel plate on the bottom of the tank but not sure on this.  :jester:
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
