Lower Grill and Block heater plug mount
rft
Just got done installing a lower grill I got from Mountains to Metal and took the opportunity to use grill as a platform for my Block heater plug.
Handy and clean.
Looks clean. Where did you get the plug end flange with the 4 bolts? I think the trucks just have a standard cord male end?
Where did you get the block heater plug?
Sent from my Moto G (5) Plus using Tapatalk
Thanks.
Got the plug here, its a Noco Genius plug .    I made the bracket that fits behind the grill.
Used cardboard for test template then I fabricated bracket out of a a piece of .05 thick sheet metal.    I sheered the plate to be square. Press Punched (easily could of drilled if needed)four holes for the rivets once I determined correct placement, the riveted holes attach the plate to grill.   Then  Press punched a 2" hole in center of plate (a hole saw would of worked if I didn't have the punch) and then used an Air Grinder to cut out a 2" hole in grill.   Found proper placement for the Noco Genuis mounting holes and drilled those holes for mounting plug.
If I had to do it again I would of cut hole in grill bigger so that plug mounted flat onto mounting plate.
Nice job!  I haven't required a block heater for many years but I appreciate the benefits of such a modification.
Funny thing is I most likely wont need it but its there if I do. I had the grill and wanted mount the heater cord without cutting/drilling/or screwing anything into actual truck.
    Afennell19
    Afennell19
  • Who's Online   2 Members, 0 Anonymous, 753 Guests (See full list)
