2015 Silverado LT Speaker Feedback / Whine
bvaile
Good Morning. Just purchased a CPO 2015 Silverado LT double cab 5.3 4x4 a few weeks back. I have been noticing a sound coming from the driver side speakers when accelerating. Its hard to describe what it sounds like, but its not there at idle or decelerating. Under a lot of throttle it is pretty loud. I have been researching the issue but can't find much info on the newer trucks. The best I can come up with is some sort of ground loop issue with the factory radio. Any info would be greatly appreciated. I do have the CPO warranty but I do not really want to take the truck in if it could be something simple.
Might sound silly but is your 4WD engaged on either Auto or HI?  These trucks make a faint whining noise when anything other than 2HI is engaged.  It's some kind of electrical problem that I haven't seen resolved anywhere yet.
Thanks for the reply. I keep the truck on 2HI. I was flipping through the audio settings this morning and i found speed volume which was turned off... not quite sure what else it could be.
Does it make the whine on all inputs, radio, ipod, cell phone, etc? If it is from a device you plugged in like your phone or an ipod it could be coming from that device. I had an ipod once where if you plug in the charger and connect it to the radio via the headphone jack it would make a sound like having alternator whine while the battery on the ipod was recharging. You could possibly have a wire that chaffed and is shorting to ground but that is pretty hard to have happen unless someone was messing around under your dash.
It is there all the time. Even when nothing is plugged in and the radio is completely turned off.
    d.lowrey
    d.lowrey
  • Who's Online   1 Member, 0 Anonymous, 5,710 Guests (See full list)
    • Just did an injector/HPFP replacement on Pepper at 192,400 miles; close enough to 200K, RIGHT? (If 200K is considered life end and to me it isn't). But hey, to each his own.    Have never run a catch can on this vehicle. Back side of every valve looked like a new valve spray painted semigloss black. Port walls looked 'neat' (all a normal result of passive EGR via VVT) Zero build up even in AFM cylinders. Just color. It uses no measurable oil and never has.    At 155,000 I put her on E-85 and a borescope of the cylinders at plug change showed very clean pistons and valve faces. The replaced injector tips looked new. (It was the pump piston seal that was leaking). Oh well, have six good backups.    Still gets 28 mpg on gas (highway average) and over 20 (highway) on alky. UOA's look good and runs as good now as it did when I bought it. Better in fact.    What improvement would a Catch Can provide this motor?     And given all this I expect that IF I installed one I'd see some water/gas/oil vapor accumulation. Byproducts of normal combustion.   Having said that, IF my motor used an appreciable amount of oil I'd consider it a useful 'crutch' until I had the situation corrected OR if bore polished, until I junked it or rebuilt it to stave off repeated plug fouling.    I'm not telling you what I THINK. But what its DONE.
    • Love the look. I'm a SCSB lover myself.    Two items. 1.) A spacer changes scrub radius but this also changes when we use wheels of different offsets. A little isn't a big deal. 2.) Steel wheels, alloy wheels all have different thickness. Same effect on the stud and lug nut as a spacer. When hub centric the wheel isn't supported by the stud. It's supported by the hub. The stud just keeps it all together.
    • I had a evap sol go bad a couple weeks ago. . I replaced it.  While watching live data at the time I saw I had some cylinder 1 misfires. No MIL but on live data I could see ~50 at startup and about 70 more after an hour a drive all on cyl 1.  I also noticed that the LTFT were -5% to -15% always.  And that bank 2 is always -3% richer than bank 1. Even across all driving modes, city, highway, etc it’s always 3% richer than bank 1. So I start with the misfire. Swapped coil, plug, and plug wires from 1 to 3. No follow. I got an Injector reseal kit, pulled the D/s injector rail, swapped #1 and #3 injectors, resealed them, reinstalled and retested.  The misfire followed to 3. So I ordered and replaced all 8 injectors, spark plugs, and plug wires. Also replaced the 1 time use fuel pipes under the intake manifold.  Injectors that were in the truck since new were  Part # 12668390.  I replaced them with # 12742701 Got from RockAuto. Pretty certain they’re genuine and the correct ones. I called a friend at a parts store who told me “the 12742701 were the correct superseded part # for the originals I was replacing”. So started truck after replacing all that and it’s running -15 - -30 LTFTs. I reset the fuel trims with GDS2 and drove it for a 60 miles trip each way. There have been no changes in the LTFTs.  I checked if the HPFP was leaking into the crankcase. I removed the pvc and watched the trims. No difference.  I checked the alcohol content and it was at 10%  I’m out of ideas here. Truck seems to run great. Just always rich on the fuel trims.  Anyone with any help or ideas would be greatly appreciated.  I ran an injector balance test just for the heck of it and it came back this. I’m confused.  I have gds2 and some other diag tools if anyone knows of anything I should test next.
    • Definitely needs to go back to the dealer.
