Airlift Suspension
Ok, so I have Airlift 59565 ride control installed on my 2015 1500.  I've been hearing a clunk when I go over bumps in the parking lot or pulling into the driveway at home.  I cant tell where its coming from but sounds like its the bags??  Anyone else have this issue?
Interesting I'm looking at a similar if not same type kit. As I'm lowered 5". I would rather run a 2500 bag inside the frame up too low.
Sent from my SM-N950U using Tapatalk
Is that pic at normal ride height?
If so I’d imagine you’re over-extending the bag...?
I thought the same thing. IMO I think there is a max of a inch up travel and a lot of down in that setup.
Stick a peice of rubber uner the bolt the holds the bottom of the bag in. See if that works
Good idea I also have seen that they sell a plastic bag spacer mot that he needs it higher but nice Isolation
yes,  that is with recommended 10 psi inflation while not in use.
The mcg bags iused to have in my16 required 4lbs when not using
What happens to the bag when at full droop?
It looks like it’s fully extended at your ride height...and that wouldn’t be good.
They rip open. That is why a limited or the new Firestone 2500 have fully crimped bags still bad but better then rip. And you know all dealerships will just put it on the rack and lift it.
Pretty sure that’s your problem.
Your suspension will go to full droop even when driving, doesn’t have to be in a lift.
Depending on many things, including the condition of your shocks, a large compression movement like a speedbump can cycle to full droop on rebound.
While under load,  it compresses and gets fatter.  If that's what you mean.  I haven't had any problems yet.  other than the noise.  Now I'm hearing that gm has issues with the leaf spring knocking over bumps.
But if you aren’t under load, it appears to be stretched to the limit.
If your bags will tear at full droop, as you state, then that’s a problem.
In the pic it looks like ride height and there is more in the bag to go up or hang. As you dont see the bottom bag mount.
    fourhorses88
    fourhorses88
  • Who's Online   4 Members, 0 Anonymous, 875 Guests (See full list)
    • I figured you would know about it.
    • It added a cost layer to an already limited production supply. True that.
    • Swap costs and supply/demand balance. When a barrel comes out of the ground the entire range of products are present but not all at the same percentage.    Breakdown of Refined Products The following table summarizes the approximate output from a standard 42-gallon barrel of crude oil: Product Type Gallons per Barrel Percentage of Total Gasoline 20 gallons 45% Diesel Fuel 9 gallons 21% Other Products 13 gallons 31%   Most of that diesel figure is 'straight run' or cut from the barrel. Gasoline 'cut from the barrel runs 0 to 20% at the crude. So in the crude unit there is more diesel the gasoline, usually.  The full refining experience however gives the tabled values. Ego there is half the diesel than gasoline after the 'first crack' That could be an FCC unit, or Isomax or....   Those units take heavy products and break the big ones into little ones. Those numbers are harder to get hold of but directionally it ends up the same.    Really light products are very profitable. Ethylene and Propylene to name two. Those are cracked from slightly heavier feeds like NG and Propane and Ethane. The cracker harshness determines the feed for distillation. Those feeds come from less profitable products like diesel and gasoline.    So...there is a swap cost. How much market is there TODAY and what crude am I running TODAY..... what is my process capable of always.    There is this as well. The USA uses allot more gasoline than it does diesel so in the cracker the process is tilted to gasoline production which....limits supply of diesel. OTR uses the most and it has different requirements than automotive and agricultural.  Limiting auto products.    You are correct however. It is less refined, just less of it. Allot less.
    • Most thermostatically controlled ATF systems use a 'wax' pill just like the one in your water thermostat. They work on the expansion volume of the wax and the pill is constructed in such a way as to limit the travel to remain within that range. This means it has an opening temperature often called the 'cracking temperature' and a fully open temperature. For whatever reason oil is designated by it's fully open temperature and water by it's cracking temperature.    Between the two it the "Regulating Temperature" The entire range is about 20 F from closed to open. In your example the lower limit, opening point of 145 F then has a fully open temp of 165 F and a throttling temperature of 155 F.    Thing is, the throttling temperature needs two things to work properly. Enough system load high enough to reach the minimum and a heat sink (cooler/exchanger) large enough to prevent any load applied from exceeding the fully open temperature.    If your system exceeds the fully open temperature it is screaming MORE COOLER.    Here is the silly part of the whole thermostat system where the oil is cooled/heated by the radiator. Nothing is flowing to that system until the oil temperature reaches the cracking temperature unless it is equipped with a minimum flow bypass orifice or a bypass built into the seating surface of the plunger. That system meant to get it up to temp quicker isn't doing a thing until WORK drives if from ambient to cracking temp. One a cold winter day, like zero F, it may never get hotter than about 110 F. Sometimes not even that.    People forget or are young enough to not know that until this millennia transmissions were cooled by the radiator cold tank alone and without a thermostat at all.  In the 50's they weren't even cooled. OEMs learn everything the hard way.    When an OEM tells you the trans "Works best" between 175 F and 220 F it means works best for THEM. The transmission thermostat is fuel play. If you watch you trans temps like I do you will learn that it may take a hundred miles if you are not towing and not driving more than say 55-60 mph on a zero F day to even reach 120 F and it might sit there all day if it's colder. Yet if functions perfectly over about 100 F. It may need to get a bit warmer for the fuel and spark maps to go without an multiplier.    Worry more about too hot. Use a cooler large enough to put that thermostat in range.
    • Around 2008 if memory serves they took sulfur out. That was when diesel went up.
