2nd Battery?
KyleCarty
Hello All,
I recently installed a snoway plow on my 2018 Silverado 1500 (yes i know its a bad idea to plow with a 1500) and i am currently installing multiple lightbars and was wondering if the battery would be able to handle this? i know that theres a compartment to install a second battery so i was just wondering if thats the road im gonna have to go down. Thanks for the Help!
I used to plow with a Ford F-150 years ago and had one battery and it had halogen lights on it front and back spotlights that used a lot of energy, One battery work just fine. If you have a good alternator should not be a problem especially if you are running LEDs
