I’m pretty sure you can adjust it yourself... that’s what I had to do on my Colorado.
Hi. We certainly recommend reaching out to your local certified dealership to have this concern addressed. Our team is happy to connect with them on your behalf. To do so, please send an email to [email protected] ATTN: forum username/GM Trucks with your contact information, VIN, brief description of your concern,  and preferred dealership. We look forward to hearing from you. To learn more about GM's privacy policy, please visit http://bit.ly/2h3ZUnC.
Aleigha W.
Hi my $56,000 2019 rst 5.3 8 speed 8-19 build date is just like you say my drivers side is higher, the issue here is the cab needs to be lifted there is only a left right forward back adjustment on the bed, my buddy's 2020 Sierra is also the same way,  I also thought my truck was dropped off the train or someone launched it but it's just very poor quality control at gm, i don't want to make you sad about your truck but I am so disappointed in my truck, my transmission is Awful, my rear window leaks water, and apparently this is all normal and can't be fixed, gm really does not care they would do anything to save 27cents,  one positive note is I've managed to go 5400 miles without having it towed....
This sounds like my issue. I wonder if there could be a washer or bushing missing on that left rear cab mount causing it to sit lower..? Or why the heck.? For a $54,300 truck, I just expect too much I guess
58 minutes ago, Will71 said:
You could try this, gm only pays 24 minutes to fix so a $20.00 an hour tech gets like $9 subtract taxes = like $6 to fix so you should probably do it yourself if you want it right.
Correct me if I’m wrong, but this will not raise or lower the bed.. unless one of those plastic pins could be possibly pinched causing the bed to not sit down flat on the frame.?
On your transmission issue.. mine did shutter and almost felt as if slipping at times up until about 6,000 miles. Now currently it has been working perfectly.. not sure what happened but the shutter is gone. (I have been driving her hard to either make it finish itself off or fix itself.. idk if it helped or not!) LOL
Edited by GearJonny
Hi so it doesn't appear to lift or lower the bed,  in my case I need to Lift the body on left rear, I was going to get a cab mount bolt washer and  shim between mount and body, my bed is off to the right not sure if sliding it to the left will lower it doesn't appear to, I was going to adjust the bed after I lifted the body just haven't done that yet, I agree the price point of these vehicles. Bring it in line with high quality German luxury cars with high level of engineering  and manufacturing.
  • 8 months later...
TSB regarding vertical alignment is here in case anyone needs it.
https://static.nhtsa.gov/odi/tsbs/2020/MC-10181703-9999.pdf
  • 2 years later...
Have a simillar issue measured the bumper to ground on each side and its the same. Put a level on the bumper and its level. Problem appears to be the bed. So that means it could be adjusted as platform is level. You can see it when looking at bumper in relation to tail gate at the bottom. Its 3/4in off. Will have dealer take a look no accidents reported. 2021 2yr old
Update it appears the gas tank is on the left side of the truck. It is now full so 21g x 8.4lb=176lb maybe this is part of the issue.
    • 37's would probably fit with a 3" lift. GM only has two gear ratios for these trucks 3.73 for gas and 3.42 for diesel. And they can't be programmed for anything else at the moment. The rough country module just corrects the speedometer and odometer to adjust for tire size it's not a programming device.   You haven't said if your truck is gas or diesel, but for a gas truck the 10L1000 with 3.73 gears has a lower final drive ratio than the 6L90 it replaced would if it were swapped to 4.10s. GM used the same 3.73 gearing in 6 speed gas trucks. I don't think you'll have any issue running 37's with the 10 speed other than the reduction in mpg and towing/weight capacity which is as much of a function of the lift as the tire size.
    • Actually, it probably was the brakes.  It's weird the way the messages came across, but I took it to the dealer thinking that something was wrong with the sensor and in fact, the rear brakes were shot.  What I don't understand is why the messages never said, your brake pads are low.  First I got the message I posted above, taking about new pads being detected.  Then I got a message saying that the system needed repaired.  It never said, change your brake pads.
    • Did the KYBs keep it the same height in the front? I was concerned that pre-assembled assembly would raise it up an inch to standard non-z60 height.. I guess which it would make the rake 1 inch instead of 2 inches.
    • Thank you for keeping the train on the tracks and for a thoughtful engagement. I enjoyed the reflection on a previous stance to refine and improve your position. I like that inquisitive flexibility about you Atlas.    No the process isn't sterile. Hundreds, perhaps thousands of miles of piping, vessels, pumps. Chevron, the people I worked for, were keenly aware that there is a market for what is known as their "ISOCLEAN" line of lubricants. These are lubricants that are the same as those sold bulk that are further processed by filtration to a level your particular application demands. They will filter and package and provide lab documentation as required. Do not kid yourself. Every gallon of oil that goes into a Chevron Turbine, reciprocating compressor, generator is prefiltered and tested before being charged. Lest wise it was when I was there in the plants I worked in.    There are requirements set by manufactures for the cleanliness of the oils used in their equipment. OTR such as CUMMINS has standards shared with customers on this. Commercial interest selling to Ma and Pa do, but don't share that information. Not even upon request but internally, they do exist.    The GM study sited, (Graph from Machinery Lubrication in previous post) only shows "relative" importance.  I find that fascinating. By constructing the graph like this they admit there are dozens of factors in engine life and via scientific method determined the effect of 'relative cleanliness' on engine life not in miles but in 'FACTORS'. This allows a certain amount of reverse engineering does it not?   They even provided some touchstones. Beta 75 as a reference point. Wonderful stuff!!   Smaller blenders CAN and some DO take the time and effort to do better than a refinery or large bulk blender, like Warren Oil, in improving the "in the can" cleanliness. No I don't have a list but testing could generate that information.    Again, but one of several levers we can pull to improve engine life. The simplest is keeping a clean work station while doing your own oil changes.
