Interchangeable rearends?
I got a 2000 silverado 1500 with the GT4 G80 rear end with the 3.73.  So was out driving one day and i got 20x12s on it with -44 offset and just a 3 inch front level.  Well i gave it a little at a stop light while one the brake and the dang carrier exploded.  So was out looking for a rear end and found one from a 2001 Suburban (grandpa did) so im hoping its a 1500, and just curious would this fit on my silverado the whole rear end?
I got it and it has disc brakes just like mine and leaf springs is there a way to tell what gear ratio it is?
    appletrav
    appletrav
  • Who's Online   5 Members, 0 Anonymous, 347 Guests (See full list)
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
    • Thanks; I looked there a few minutes, and I think I can find something. I really never looked there, as I thought it was stuff like PTO/aftermarket bodies/accessories like snow plows.
