wheels
First time in this forum. Im still confuse about offset and backspace. I want to know how wide of a wheel and how small of a diameter of a wheel i can fit in a 2014 silverado 1500 without doing any modification to the truck. Its lowered on a 5/7 drop.I heard that a 15in wheel cant fit because of the brake caliper. Anything will help. Thanks
First time in this forum. I wanted to know how wide of a wheel and how small of a diameter of a wheel i can go in a 2014 silverado 1500 without doing any modification to the truck. It has a 5/7 drop kit. Im still confused about offset and backspace. Anything will help. thanks
You can only go down to a 17" diameter wheel.
5 hours ago, loweredsilverado2014 said:
will you know how wide of a wheel i can fit in the truck? I dont mind if its sticking out a little.
17x9.5 with +25 offset needed a 1/4" spacerto clear the banjo bolt on the rear brake caliper
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
