Wheel Size And Offset On Lowered Truck
My truck Is lowered 6 rear and about 3.5 in the front. The wheels I'm looking at are 22X10's w/30mm offset so the backspacing is 6.68 in., with tire 275/45-22. Will I have clearance issues? What is everybody else running?
I have 24s and 295 tires they clear with a 3/5" if I went 22×10 i would run the 305.
Need to know factory specs and then work the numbers. I have well over say 1" as my air bag mount clears.
Me being at 4/7.  A 22x9 +30 offsetwith a 275 40 22 cleared thr fender lip by about 1/8"
Thank you both for the input. Really appreciate it!
  • 1 month later...
Just joined the site & getting to do some work on my 2018 crew cab. Did a 4/6 drop and plan on keeping factory rims, whats the opinion on using a 275/45/20 tire? Will it minimize the rub during turns enough? Hate to add too much clearance using an even lower tire....
In these pictures.  I ran a 265 50 on top. And on the bottom the rears were a 275 45
1 hour ago, Ibisfan1 said:
Looks good. 265/50/20? No issues?
Slight rub at full lock but that was it
Thanks for the input, Nasty. I think I'm going to go with the 265/50/20. Seems the slightly more narrow tire (265 vs 275) also makes the difference.
16 minutes ago, DESERT DOG said:
Nasty, are those Race Star wheels? I love them.
Yes theyre gone though
I ended up with a set of BF Goodrich Advantage TA Sport 265/50/20. No rub and looks as I was hoping. Appreciate the suggestion, Nasty.
39 minutes ago, Shibbby911 said:
Looks good I’m gunna have to go down a tire size also
What size are you running now?
    Jmuck1
    Jmuck1
  • Who's Online   4 Members, 0 Anonymous, 761 Guests (See full list)
