HVAC problem with 2001, blend doors not calibrating automatically goin into defrost default mode
What started off as my heat only blowing on the face vents, now the system is in default.
I replaced the mode actuator with a GM one and tried to calibrate it and after installation it only goes to defrost.
I thought it might be a bad control panel bought one and now when you plug the new one in, it cycles thru all the cycles and Goes back  to default.
At first I was getting a BCM code of a aspritator only to find out mine was unplugged. I plug it in and now the code is gone but still only defrost...
Has anyone experienced this before. I am completely lost right now and I even had a friend from Chevy look at it on a GMscanner. He manually opened all the blend doors and when you shut the truck off back into default...
Pulse motor is blocked, and trying to reset. Grab a cheap Scope for your smartphone and find out what fell into the defroster duct.
I have a similar issue with hot and cold blend door if I pull the circuit breaker on the driver side it will work for a couple minutes then stuck in whatever it’s last position was.
What is the calibration method you mentioned?
What BCM codes are/were you seeing and what kind of tool are you using to pull them up?
