Radio bezel
I have a 2015 Silverado 1500 LT. I removed my radio bezel because I want to change out the switches. In doing so, when I took off the bezel there were 2 dead harnesses attached to the bezel.. I'm assuming they are for the upgraded model with heated seats and moveable pedals... does anyone know if that's what they're for?
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
