2014 1500 silverado 5.3
Hello i had just put up a post ..on 2014 silverado hasitation hard shifting seems like miss fire smothly pressing on the peddle hasitation at 70 75mph
Also at varies at difrent speed
first code p0308 came up ..
Replaced coil and spark plugs
Truck has abput 100k on it.
Need some help on trouble shooting the problem
I repostes this up againg new to the forum dont knw how to work this
Did you replace the plug wire? You have a misfire on cylinder #8.
The code indicates an ignition problem on cylinder #8. You say you replaced the coil pack and the plug.
1. Are you certain you replaced the parts for the #8 cylinder?
2. You did not mention whether you changed your plug wire or not. Try swapping wires with another cylinder's wire (at both ends, not just one) and see if the problem follows where the #8 wire went.
Sent from my SAMSUNG-SM-J727A using Tapatalk
Thatnks for the reply and no i ha e not replaced the wire on #8
I had the #8 just cleard code
Check inguine light haven't poped up yet
But sure can fill the hesitation and hard down shifting or shifting on #2.3 and speed vearies
No i di t not changed the spark plug wored but yes did reply the spark plugs a around..
Yes did replced coil on #8
Still having same problem othere thing i can think of could be injector .
I would get it checked out soon, driving with a misfire can destroy your catalytic converters very quickly.
Try swapping wires over from another cylinder. Let us know if the issue follows to the cylinder with the suspect wire. If it does, you need a new plug wire for #8.
Yea i will just do t ha e the found to take to a dealer ..
Need question anyboday with issues lime this .
Thanks
Also check to see if the following recalls have been performed on your '14:    ( Don't know if all of these are applicable to your VIN or will help your current situation - I'm going off my '14 GMC. )
14192 - Reprogram Transfer Case
15304 - Reprogram Transfer Case Module
Hell guys tha thanx for that help narrowing down my problems no more check ingine hasitation and hard shifting on 2/3 gear .are still there ..been srinving in manuel mode once shifting in to third i get lac of powere high rpms
Which makes me think is the trasmission starting to sleep on does gears every othere gear is smoth no problem at all
Code p0308 no longer stored or light coming on did replaced thay specific coil witch took away the problem
Will be taking it to a transmission specialist for this
Thanks everyone. For them opinions/help
Good luck, glad to hear one of the problems has been solved. How many miles on the truck?
16 minutes ago, Lolo25 said:
If has just about 100k
Do you know if it has ever been serviced, fluid change?
    appletrav
    appletrav
  • Who's Online   2 Members, 0 Anonymous, 501 Guests (See full list)
