2006 5.3 Engine knock
2006 silverado 5.3 130k 2wd
Symptoms - knock coming from drivers side wheel well. doesnt seem to be exhaust leak as it sounds mechanical metal to metal type sound. it doesn't happen directly on start up but as it warms up to about 205 degrees then stops as it reaches roughly 210 degrees. This is the only time it happens. Some times it is louder than others. some times it seems to last a little longer than others.
I have tried sea foam and a flush the place that does my oil changes recommended. Neither seemed to work for more than a few days.
I have read it could be piston slap but that seems to be more on start and disappears after warm up. there seems to be no loss of power before or during knock.
Oil pressure reads fine while knock is happening. As I write this I remember replacing the oil pressure sensor and feel like the knock might have started after that at some point.
I will try and post a video of the noise shortly.
You could use a 3' wood dowel for a stethoscope,one end to ear other to various places to try to isolate the noise
No CEL or codes? Curious this happens only in a 5 degree window of coolant temp. Throwing something out there that may be off the wall, but I wonder about a lazy or faulty knock sensor.
Hard to tell from the video but it sounds like a rod knock. They generally are louder until the engine warms up and can fluctuate in noise level. It's been awhile since I've heard piston slap but I don't recall it ever being that loud and obvious. I'd try a can of BG MOA and see if that helps any.
    appletrav
    appletrav
  • Who's Online   5 Members, 0 Anonymous, 342 Guests (See full list)
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
    • Thanks; I looked there a few minutes, and I think I can find something. I really never looked there, as I thought it was stuff like PTO/aftermarket bodies/accessories like snow plows.
