lean condition
check engine light came Analyzer said lean condition . What causes this and should I be replacing something?
Thanks  2009 sierra HD 6.0
A lean condition is when the engine is receiving too much air and not enough fuel.
What causes a lean condition: vacuum leak on intake, cracked intake hose, bad B1 oxygen sensor, intake manifold gaskets bad, fuel pump not strong enough etc
What specific codes does the truck have?
will get them thanks
yes the code says PO171 thanks again
8 minutes ago, riverbanks said:
Without the proper tools,i.e.,scanner,I would change the o2 sensor on drivers side
Is that what the code says
Yes and no,a problem is highlighted at b1,02 sensor,so, sensor fault?,or it's telling the truth,and problem is upstream
the code says PO 171
The 02 on drivers side saw a problem,is it the sensor itself or a actual reading?,you mentioned"analyser"in first post,more like code reader, you got to read the internals of the system,i.e.scanner,is the o2 behaving?or is it the source of the code?if it is old,change it,source or not,they get tired,so a new one is a benefit for you,no cheapo stuff,buy denso
Just because a check engine code says O2 sensor is showing a reading out of limits does not mean you should just go change the O2 sensor.. what if the O2 sensor is working the way it should and something upstream of it is causing the issue (which happens more often than not!)  Proper diagnosis is key.  Throwing parts at something is just wasting money.
