Radio
Keone78
What’s up guys I have a 2015 Silverado. Is there a update for the radio ? If so what needs to be done ? I heard the dealership charges an arm and a leg to update ?’
Not that I know of. I have a 2015 Sierra and have never done any updates.
My 2014 had some updates loaded a couple of years ago when I complained about Bluetooth dropping issues. I think that added an extra display theme.
Sent from my Moto Z2 Play using Tapatalk
I’ve been hearing about a update but no confirmation on it . Maybe I should call the dealership ?! They’ll probably say no ....
If there’s an update available why would they say no? Especially if they’re going to take your money to do it...
    contrabombarde
    contrabombarde
  • Who's Online   2 Members, 0 Anonymous, 1,355 Guests (See full list)
    • Still looks like a rivet to me in the pics, I don't see a nut and none of the pics show the head of the screw. But if you says so.....
