Connectors on battery terminals
How are you guys attaching connectors to your battery terminals? Or what connectors are you guys using?
Ive been using the spade fork style connectors and can only attach 2 but want to attach a couple more but the factory style bolt doesnt loosen enough
How are you guys that have multiple lights and light bars hooking up??
If you open the plastic cover on the positive battery cable, there is a distribution block with a bunch of studs and nuts to connect to battery +12V.  On the ground side there is only the one nut on the battery cable clamp itself.  I hooked a charger quick connect to this ground and used other bolts around the engine compartment and radiator support for other connections (HID ballasts, etc)
I feel dumb! I didnt know that was a distribution block
Thanks
