Plug and play module for adding amps
Nasty
Can anyone else confirm or deny if they fit or not? Don't want to be the guinea pig and buy one to find out it doesn't fit. I guess I lose the storage for the jack and tire iron?
I would love a box that just takes up one side so the jack and tools stay on the other side. I really don't want or need more than one 10". I may have to go with a custom box.
Sent from my Pixel XL using Tapatalk
I just got the fox acoustics box http://www.foxacoustics.com/ProductDetails.asp?ProductCode=GM-CC-210-V-07&CartID=1
and put 2 sundown 10's powered by a Rockford amp and let me tell you it hits hard. I am very happy. I used an ac lc2i to get signal at back wall from bose amp. The fox box is really put together nicely and comes with 1 inch spacers to lift the back seat up for proper clearance and the sundown subs mounting depth fit perfectly into the box. I used to swear by JL Audio subwoofers but for their entry level subwoofers the sundowns are impressive. Setup works great in the crew cab!
That looks pretty nice, and is a great option. It's nice to know that it fits the new trucks. What did you do with the jack and tire iron?
I would probably prefer a sealed box. But if that box fits, then so will other boxes...
  • 9 months later...
Any pics of the setup?  I’m interested to know what you did with the jack and tire iron as well. Also, does the box have an area built in for mounting the amp?
    Fishboat
    Fishboat
  • Who's Online   2 Members, 0 Anonymous, 510 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
