2002 Silverado not blowing hot air
I just bought a 2002 Silverado 1500, and just had a problem start. Drove it Saturday and the heat was great, heated up right away and blew hot air immediately. Yesterday and today it won't blow hot air, even once the truck is up to temperature. Not sure what would cause this sudden of a change, any ideas? Thanks!
Check coolant hoses going into the firewall first. They should be hot on one side and hot to warm on the other side. If not, the core is plugged. If hot, then blend or control.
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
