Black all terrain badges
Summit850
Looking to replace my OEM badges with these, only trouble is they seem to only be available in the smaller tailgate size and not the larger size that come on the lower part of the doors. Anyone have any luck finding the door badges? 7a41715bc2afdc3faaefddf46386cf4f.jpg
Sent from my SM-G960W using Tapatalk
Keep looking, I found mine on Ebay. I ended up buying three of the larger 7" emblems for my doors. Then had to buy three of the smaller 6" emblems for the tailgate. Ended up selling the other two tailgate emblems that I didn't need.
  • 1 month later...
I recently purchased a 2016 All Terrain X. When shopping I invisioned converting the red badges to black as well. Now that I’ve purchased, the red badge on black has grown on me and I’m rethinking. Did you end up applying the black badges? If so could you post pics?
As for original question, I haven’t found different sizes available either but started thinking It wouldnt be a big deal to apply the same badge to door and tailgate.
I've found door badges and tailgate ones all correct sizes. Unfortunately winter is just coming to an end here so I havent got around to peeling the original ones off yet. Also waiting on my new centers and GMC logos to come in. So I can do it all at once. Also considering getting them color matched.
Pulled that off Instagram. If that helps you any.8a654dd73c80114333948e8227df03c8.jpg
Looks bigger than the narrower original. How’s the quality? Is that on Tungsten Metallic? Black version looks sharp on it! Thanks for posting pics.
That's just a photo I found while searching, but the badges I bought are exact same size and quality seems to be right there with oem. And that's on a gmc so I believe its iridium metallic.
Here are the ones I found on ebay. Installed earlier this year. They have went through one winter and seam to be holding up.CBF5055B-955D-4BBB-968E-51880E4CBEF5.thumb.jpeg.80a6f7ae9d9792c1d368f794a7f12f3d.jpeg
I just painted mine with Plasti dip. It's been on there for two years, I'll post pictures later if I get a chance.
    President Roberto
    President Roberto
  • Who's Online   1 Member, 0 Anonymous, 209 Guests (See full list)
