Just now, TXGREEK said:
Not good bud
Sent from above
That’s why I ask and get so many different replies...
  • Replies 41
They should be flat
Sent from above
1 minute ago, TXGREEK said:
Not good bud
Sent from above
To be honest, you’re the only one who has said that. NOT saying your wrong because I stated from day 1 I don’t know $hit about this stuff.
3 minutes ago, TXGREEK said:
They should be flat
Sent from above
That is full left lock, they are not as bad with wheels straight. Here is with wheels straight...
6 minutes ago, TXGREEK said:
They should be flat
Sent from above
So basically any level is going to skew the angle but what is considered acceptable?? We have talked and you know I respect your inputs but I’m not doing a lift YET...maybe after they 3D print my new knee lol
Here’s how they should look
Sent from above
Sent from above
Yes I know, and how does one get that with any level?
I guess new ucas, I'm curious about what size tires can be run on the stamped steel control arms with an upgraded uca, some of the 2014 and 2015 can run 285/65/20 but have not seen any of the newer ones able to hardly run 275/60/20
You don’t without lowering your front differential or....heehee CST Lift [emoji6]
Sent from above
This is the reply I got when I inquired about changing UCAs being compatible with stock wheels:
To some degree they are. The concern would be certain high offset wheels (like the OEM wheels) and wider than stock tires may rub the arm. To clear the arm with larger tires may require wheels with less back space than a stock (smaller / narrower) size tire does. That's why CST recommends a wheel with less back space than the factory wheel.
You don’t without lowering your front differential or....heehee CST Lift emoji6.png
Sent from above
Exactly! That’s AFTER I get healthy and have a new knee...hard enough now ?
With my 2018 and with a front 2.25” level and an added 1” block in rear I ran a 285/60/20 but had to get new wheels with a plus 1 offset or you’d be screwed if keeping stock wheels then you’d maximum do 275/60/20
Sent from above
Sent from above
That’s what I have 275/60R20
Exactly! That’s AFTER I get healthy and have a new knee...hard enough now [emoji16]
Just get new uca’s, you’ll still be at an angle but the new uca’s will have better articulation
Sent from above
    Brendan C
    Brendan C
  • Who's Online   1 Member, 0 Anonymous, 1,189 Guests (See full list)
