2019 1500, had it since december, suddenly the radio keeps turning off and the back on again, usually every 3-5 minutes while driving. anyone have the same problem or know of a fix. Taking it in on Tuesday.
Does your gauge cluster go blank at the same time?  I've noticed music getting choppy occasionally and one time I saw that the cluster crashed/rebooted at the same time.
  • 10 months later...
  • 6 months later...
I just got a 2020 silverado 2 weeks ago and the last two days this happened to me twice. Im going to dealer tomorrow. Did you ever get it resolved? What did the dealer say?
  • 2 months later...
Mine just started crashing and rebooting every few minutes one day last week. I had gone to Best Buy and bought a new pair of wireless earbuds and when I got in the truck to leave I plugged them into the usb slot in the console to charge them on my way home from Best Buy. Almost as soon as I plugged them in I started getting a message saying my SD card wasn’t working or was removed and the radio would crash every few minutes. Didn’t attribute it to the headphones though. I actually stopped by the dealership on my way home and they made me an appointment to come by the next day. When I got home I unplugged the charging cord for the headphones and everything stopped. Didn’t think charging headphones would mess with the radio and stuff like that because I’ve always had a pair of headphones charging in my truck for the last year that I’ve owned it. For some reason the truck didn’t like the new headphones. Anyway, be careful what you plug into the USB ports.
  • 2 months later...
I have a 2019 Chevy Colorado, my radio also turns itself off and back on while driving. It has since 36000 miles was hit. And just yesterday I was on the phone and the screen showed it was still connected but I had to turn on phone speaker just to end the conversation. It reconnected when they called back. I work from home so I don't drive often, mileage is 36645 currently. And all diagnostics show everything is as it should be. UGH! This is very frustrating and potentially dangerous in my opinion.
  • 3 months later...
We’ve got a 2020 GMC Sierra that we use Apple Car play with. We’ve had the radio randomly shut down since we purchased the truck brand new. The dealer can’t find anything wrong. We’ve got to shut the truck down for several minutes to get the Bluetooth and Apple Car play to work. Has anyone been able to resolve this issue.
  • 3 months later...
  • 6 months later...
  • 2 months later...
I have a 2022 GMC Dinali that is having the exact same problem the radio turns off and then turns back on again after a few minutes. Does anyone have any kind of a solution for this problem I’ve got 600 miles on my new truck.
My 2022 LTD High Country is doing this . It did it twice in the last two weeks.
Don't really want to take it in if they can't fix it. It sounds like they have no idea.
Any updates on the situation?
  • 2 years later...
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
    • PCM?  These don't have a "PCM".  Powertrain Control Module.  They have an ECM (Engine Control Module) and TCM (Transmission Control Module).   Do you mean update the radio?     You can check what version you have in the settings page.  Should be Y181 but there might be a newer build they can update it to.
