Adding alarm to keyless entry..
Hi all,
New to board, glad to meet you all. I have a 97 GMC Suburban SLT with keyless entry. I don't believe it has an alarm set up, as I have tried to hit the "lock" key on the fob twice..no horn sound. Would like to have at least the Factory Alarm set up on this vehicle. If I take it to the dealer could this be added or activated? I know I could go aftermarket alarm set up ..then that, I guess, would replace the stock keyless entry system. Just leery of the guys and the alarm install place going in and chopping up everything behind the dash to get "their" stuff in.
Has anyone had any luck with an after market set up that they have installed their self? I was thinking of the "UNGO BOX" system as I would like to keep this vehicle for as long as I can.
Also have the stock 235/75R15 rims on the burb..what is the largest 75 series, or widest I should say I can go to with these stock rims..and keeping somewhat the original height. If I would go to a 17 inch rim what would be the widest allowable tire to maintain the original heigth ratio? Thanks again for all the info in advance!
Joe..peace <*)))>< :thumbs:
I like the viper setups..........
Very reliable and easy to install. Plus I think it would be cheaper then having the dealer install something....... :thumbs:
I own a AudioVox Prestige. Terrible. I actually think the alarm would be alright, but I let Car Toys install it for me :confused: Only reason why I went with the AudioVox was because they didn't have the Alpine that I wanted. Alpines are nice. Not too expensive either.
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
