TPMS relearned by itself?
I am baffled. I recently bought aftermarket rims and had TPMS sensor installed on the rims. Yesterday I removed the stock rims and put on my new rims. I purchased the relearn tool and watched the videos about how to do the relearn. I started my truck and looked at my tires pressures and without going through the relearn procedure, the correct tire pressures were displayed. I went for a short drive, thinking that the truck was still, somehow, reading my stock tire pressures. Nothing changed. Still showing tire pressures. How can this happen?
How short was the drive? takes mine about 10 minutes to realise.
Sent from my Moto Z2 Play using Tapatalk
Did the tire pressure change on the drive to be 100% sure it wasn't still holding the pis from the signals from the old tires in the garage?
It was holding the old pressures. After a 20 minute drive it went to blank pressures. Used my eBay tool and it worked perfectly. It's all good now. Thank you to all.
    contrabombarde
    contrabombarde
  • Who's Online   4 Members, 0 Anonymous, 1,197 Guests (See full list)
    • Some clarification may help with some of these issues.   - Rev Industries is/was the division of BAK (now Realtruck) that makes covers under the OEM names.  So if you see one with a Ford logo on it, or if you are buying the GM Accessories cover, you are essentially buying a BAK G2 cover with different branding.   - Rev Industries now markets under RealTruck "Advantage."   - As of May 1, 2025, the Advantage covers now have a 5 year warranty.  Anything before that was a 36/36K warranty.   - Parts for the covers are available from Realtruck or BAK.  The email address to reach them is [email protected] or you can call them at 818-365-9000   - If the entire cover has to be replaced, you have to go through your local GM dealer.  Service dept opens an RO, notes the damage and submits it as a warranty claim.  Keep your paperwork handy so they can confirm when you purchased it and it's within the warranty timeframe.  Once the warranty claim is approved, Parts orders the replacement cover.  When it arrives at the dealership, service will remove and install the new one for free as labor is included under warranty.   - The Advantage covers are not the latest and greatest Gen 3 covers.  They still use the old school clamps, elevator bolts, etc...If you want the newer technology, consider buying your cover in the aftermarket world.  That way, if you have an issue you can deal directly with the manufacturer.   - Finally, RealTruck has a program with many of their authorized dealers that doubles the warranty to 10 years if the authorized dealer does the install.     Hope this helps.
    • Welcome to the group!  My '22 just crossed 150K miles.  Runs perfectly.  Oil pump belt will be done in the next 30 days or so and onward hopefully for another 150K.  Love the truck.
    • Still looks like a rivet to me in the pics, I don't see a nut and none of the pics show the head of the screw. But if you says so.....
